Oliver 77 piston ring set
John Reilly
08-23-2000 07:32:12
I recently bought an oliver block with the head removed one month ago. I covered the block with plastic to prevent any further water damage. However, I want to tear the block down and hoe the cylinder walls and replace the rings. The white dealer wants $46.00 per ring set. Does anyone have any suggestions of where I can buy a ring set without spending nearly $300.00?
Bob K.
08-23-2000 18:44:13
 Re: oliver 77 piston ring set in reply to John Reilly, 08-23-2000 07:32:12
You should be able to get rings at a NAPA dealer, or any decent auto parts store where someone will spend a little time with you. Take careful measures of the bore size, and bring a piston with you. You probably have (3) 1/8'' rings,and an oil ring . The trick is getting the right oil ring. A diesel may have a 1/4'' ring, while gas may have a 3/16...however...some gas engines have diesel pistons with the wider oil ring...other than that...they ain't nothing special, and should be 100- 125 bucks or so. Happy huntin'...
