1946 Oliver 70 6 speed shift pattern???
Jim Warren
08-17-2000 07:12:03
Howdy, Just got the ole Ollie Running and need the run down on the shifting pattern, Reading the msgs, I think its a Six speed, Can someone Tell this Seattle Yuppie were them gears are? I seem to have a Hi lo and have found some of them..
Thanks for all your help... I love this board, It has been so helpful.
David C. Baker
08-16-2001 20:37:34
 Re: 1946 Oliver 70 6 speed shift pattern??? in reply to Jim Warren, 08-17-2000 07:12:03
Both Mongo and S. Green are feeding you ....
The "upper" (front)set is: up left, 5th (right into the ignition switch); up right, 1st; back left, 2nd.
The "lower" (back) set is up left, 6th; up right, 3rd; back left, 4th; back right, reverse. It's conceivable I have the 4th and reverse reversed. I am sitting in an office 100 miles away from the farm.
Mongo who quoted you stuff on the 55 I believe is quoting from a left-handed shifter on that model.
I own a '70, 1946 model. I'll send you a picture by e-mail.
D. Baker
[email protected]
roger felton
01-28-2002 11:19:06
 Re: Re: 1946 Oliver 70 6 speed shift pattern??? in reply to David C. Baker, 08-16-2001 20:37:34
send me if any one can the exact shift pattern on the oliver 70 rowcrop "6 speed W/ hi lo revers"
Mongo
08-17-2000 19:32:42
I spend more time on my 550 and I have slept since then, but let me give it a try.
All the way to the left and forward (to where your knuckles are almost in the dash) is R2, straight back is 4th, up to the right is 6th and straight back from there is 3rd. Now center the shifter in neutral and pull back into another "H" pattern. To the left and forward is R1, back is 2nd, the right and forward is fifth and back from there is 1st.
It is a double "H" pattern with connecting journal from the middle of the neutrals to one an other. I may have the 3/4 and the 1/2 backwards, but this gives you the idea. Hope this helps.
Scott Green
08-19-2000 03:12:55
 Re: Re: 1946 Oliver 70 6 speed shift pattern??? in reply to Mongo, 08-17-2000 19:32:42
Both of my Oliver "70s" only had one reverse. It's been so long now , that I don't remember the shift pattern.
