1967 Oliver 1850
Ron Housh
12-13-1998 20:31:51
Need to know the manufacture of the 6 cylinder diesel engine and what horse power it is.
john hume
12-31-1998 15:21:05
 Re: 1967 Oliver 1850 in reply to Ron Housh, 12-13-1998 20:31:51
1850 diesel is a Perkins, it is unlikely that someone changed engines, because the frame was made for the Perkins and is unique.
Denny
12-16-1998 18:06:35
Any Oliver 1850 Diesel regardless of year has a 352CID Perkins engine. The only other engines offered in Olivers were Wakashau, Hercules, Catapiller and GM(Detroit). If your tractor is a true 1850 Diesel it will have a Perkins. The only Perkins put in Olivers was the 352CID 6 cylinder. Hope I could help,
Denny
Thomas Bane
03-20-1999 05:22:17
 Re: Re: 1967 Oliver 1850 in reply to Denny, 12-16-1998 18:06:35
I have a 1650-1655 Oliver tractor, looking for
used parts to convert to manual or 3 point hitch
operation.
The Professor
12-18-1998 19:28:00
Oliver also used Continental engines (in the Super 44/440) as well as Minneapolis-Moline engines in the 2055, 2155 and 2655. Don't forget that Oliver also sold tractors under their name buit by David Brown as well as Fiat.
Pete
12-14-1998 05:56:39
Ron, If memory serves Oliver offered several diesel engines in 67. Your best bet would be to pull the serial No. and check at a White dealer.
The HP should be 92/93
