Trailering an Oliver 66
Kevin Uhl
08-16-2000 19:47:38
Can anyone tell me the approximate weight of an Oliver 66 with wide front? Would also like to know if this tractor could be hauled on a 6 x 12 car trailer with an F150 1/2 ton (351 engine).
Steve in CA
08-22-2000 10:39:43
 Re: Trailering an Oliver 66 in reply to Kevin Uhl, 08-16-2000 19:47:38
I'd also be sure that the trailer has electric brakes, and your truck has a controller. That's a lot of weight to pull. You mentioned it's a car trailer, so it's probably set up with a tandem axle and brakes.
Dennis(WA)
08-17-2000 09:51:14
You better measure the outside width of the rear wheels. Your 6 foot trailer may not be wide emough. My 77 measures 6' 9" wide.
Pete in Ks
08-17-2000 06:21:57
You didn't give much info on the trailer. If the trailer is a tandem axle then you will probly be OK. If it is single axle I wouldn't recomend it. Your truck has enough engine but without more info on it's equipment setup and your towing conditions (hills,mountains,distance etc..) I can not and would not say. Your Ford dealer can tell you what your truck is set up to pull.
Shepherd
08-17-2000 05:16:14
The book says that this tractor would weigh 3,041 lbs. That might be a little much for a small trailer. The truck should be able to pull that.
Oldtractor
08-16-2000 22:23:26
Not sure about the 6 foot wide. I haul a Super 88 6400, with a 318 dodge ram does fine. Don`t think the truck will be a problem,
JR.
11-26-2000 17:33:08
 Re: Re: Trailering an Oliver 66 in reply to Oldtractor, 08-16-2000 22:23:26
Tractor #3,150 its 11feet long
its 6.4 wd.
truck ok
tra. ng
JR.
11-26-2000 17:31:54
its 6.4 wd.
truck ok
tra. ng
