Oliver 770 paint numbers
W Fraser
02-06-1998 19:00:55
I have 2 problems, the first one is the Martin-Senour numbers cannot be cross referenced here. I took these numbers into a paint supplier in Edmonton and the guy looked at me like i was growing a second head or something.
The second problem i have is trying to locate the correct paint number for the white stripe that is on the tractor.
Thanks
Wenn
Bob Skurka
02-10-1998 05:50:07
 Re: Oliver 770 paint numbers in reply to W Fraser, 02-06-1998 19:00:55
: I have 2 problems, the first one is the Martin-Senour numbers cannot be cross referenced here. I took these numbers into a paint supplier in Edmonton and the guy looked at me like i was growing a second head or something.
: The second problem i have is trying to locate the correct paint number for the white stripe that is on the tractor.
: Thanks
: Wenn
If you have the Martin Senour numbers, you should be able to contact DuPont and have them convert them to DuPont Dulux numbers. Get in touch with a regional office the company here in the States. They should be able to convert it for you. If you are lucky, you'll find a regional guy who can do it for you. Your other option may be to order the paint and have it shipped to you.
