1755 Steering Problem
Joe
07-27-2000 14:58:45
I have an Oliver 1755 and last winter I had problems with the steering freezing and not being able to steer. after warming up for about an hour it would un-thaw and work fine. Any ideas. i'd like to get it fixed before this winter. Thanks for the help!
barry
01-28-2001 16:52:12
 Re: 1755 Steering Problem in reply to Joe, 07-27-2000 14:58:45
joe i to have had the steering freeze up on my 1755 and still have the 3 point and other hydraulics working.just wondered if you found the problem?
B A Star
07-27-2000 21:32:31
The steering system gets its oil from the main pump. When it freezes up does the other hydraulic functions work (ie rockshaft and remote valves?) The steering control valve is a TRW Ross, generally they have been trouble free. I know you want to correct it now, however it has to demonstrate the problem before you can trace the cause.
Joe
07-28-2000 09:23:22
 Re: Re: 1755 Steering Problem in reply to B A Star, 07-27-2000 21:32:31
The three point hitch does work when the steering is frozen.
Thanks for the response.
larry wolfe
07-28-2000 09:58:49
 Re: Re: Re: 1755 Steering Problem in reply to Joe, 07-28-2000 09:23:22
I would suspect a sticking flow divider,or something sticking in steering valve. I would check the multiple valve that regulates the flow to all the parts of the system. Its the large valve on the left side near the pump. I think the one valve you need to see if its free is on the top front.
