Pump Timing on 1650-D
Skinner
07-21-2000 18:53:29
I just rebuilt my older style 283 (pintle injectors and flat top pistons) and stabbed the injector pump. My book says to line up the proper line on the flywheel the line up the lines in the pump. Thats no problem, however,on my flywheel I see 1 deep mark that is stamped TDC and the only other mark I see is a very small mark about 3/16" away from the TDC Mark.
Does anyone know what the timing is suppose to be and is the small mark the one I need to use?
Wrenchbender
07-22-2000 06:16:57
 Re: Pump Timing on 1650-D in reply to Skinner, 07-21-2000 18:53:29
My book says 2 degrees BTDC for a 1650. If the small mark is on the BTDC side of the TDC mark then I'd guess that is 2 degrees. I thought most of those had a timing tape on the flywheel, maybe it has come off and someone has marked it this way. Good luck,WB.
Skinner
07-22-2000 06:30:08
 Re: Re: Pump Timing on 1650-D in reply to Wrenchbender, 07-22-2000 06:16:57
Thanks. I did some calculations this morning to verify this. The flywheel od is 14.075
so... (14.075 * pi) / 360 = .125" per degree
so the 2 degrees BTDC should be about 1/4 BTDC.
I appreciate your help, I'll go out and see how close that mark is or create the proper mark.
