Hydraulic oil going in the transmission
Nelson Poulin
07-18-2000 18:24:43
Hi, on my super 55 the hydraulic oil is going in the oil of the transmission and differential.Why its happens and what I can do to repair this trouble. Thanks
larry wolfe
07-19-2000 09:19:10
 Re: hydraulic oil going in the transmission in reply to Nelson Poulin, 07-18-2000 18:24:43
Most likly the hydrolic pump is leaking.You have to lift entire hyhdrolic unit off tractor to fix. When you do check pan for leaks to.
larry wolfe
08-15-2000 18:29:03
 Re: Re: hydraulic oil going in the transmission in reply to larry wolfe, 07-19-2000 09:19:10
you are wright the pump was leaking by a o'ring thanks. nelson
