Oliver 1950 pto problem
Mike O
07-10-2000 06:21:43
My Oliver 1950 consistantly shears the cotter pins used on the egagement links on the over center pto clutch. Usually, one becomes unhooked or even breaks and then the clutch goes. any ideas why this is happening and what i can do to fix. we use this tractor along with several other olivers to pump water using the straigth thru pto shaft in the top outlet. My 2150 doesn't have this problem.
larry wolfe
07-10-2000 10:38:20
 Re: Oliver 1950 pto problem in reply to Mike O, 07-10-2000 06:21:43
The service manuel says the head of the pins must be faceing the direction of engine rotation.
