Gear oil
Doug
07-02-2000 12:24:33
I recently bought an 1956 Oliver Super 55. It came with a shop manual but I can find no refrence to what kind of oil I should put in the transmission and differential. Please give me a hand.
Dennis(WA)
07-06-2000 14:35:20
 Re: gear oil in reply to Doug , 07-02-2000 12:24:33
Eric, see my incorrectly posted reply under Super 55 generator.
chief613
07-04-2000 05:06:02
I was told by the local parts store to use 80-90w, supposedly they called a mobile rep and he said that back years ago there wasnt oil thick enough and the oliver addative was used to make a light oil stand up to the heat and friction of a heavier oil. they said to definatly NOT to use transmision oil as it would burn up the transmision and final drive. So i use 80-90w, and have had no problems. So take it as u like, this info is from across the counter of an auto parts salesman
Scott Green
07-04-2000 15:39:08
 Re: Re: gear oil in reply to chief613, 07-04-2000 05:06:02
Chief , Years ago , motor oil did not have the additives in it, like todays oils. From what I understand , Oliver additives were to help prevent foaming of the oil.Foamy oil does not lubricate as well.Foamy oil also does not respond as well in a hydraulic system. Today , a lot of these additives are in the oil when you pull it off the shelf. That is why the average consumer does not have to add any.
EricR
07-02-2000 22:21:18
I have a copy of the Shop Manual and this is kind of long, but this is what is says under the heading "LUBRICATION-TRANSMISSION, DIFFERENTIAL and FINAL DRIVE:
Beginning at tractor serial number 60 501-000, all tractors had SAE 5W-20 or 10W-30 engine oil and Oliver 102 082-A tranmission oil additive in the transmission, final drive, belt pulley and Power-Booster Drive reservoirs.
Multiple viscosity SAE 5W-20 or 10W-30 has a more constant lubricating ability at all temperatures, whereas SAE 90 and 140 is thick and does not circulate at low temperatures.
Hope this helps!
Mongo
07-02-2000 19:40:44
Everyone says something different. Anything from 30w to gear oil. I use 80w-90 in mine. I am in southern Indiana and it is a little stiff on a cold winters day until it runs awhile, but it hasn't given me any problems. I believe they had 30w with an additive that is no longer available from the factory, but I may be wrong on that one.
