Oliver 1800 transmission oil
jim
07-02-2000 06:39:43
recently bought 1800.Need to change trans oil + other fluids. Need to know type and amount of fluids . Any help greatfully Appreciated.
jim
highboyford
07-03-2000 13:51:13
 Re: Oliver 1800 transmission oil in reply to jim, 07-02-2000 06:39:43
The tranny holds 2-3/4 gallons of 80/90 gear lube.Final drive holds 9 gallons of same.
The hydra power uses automatic tranny oil(type a)and takes 6 quarts.The pto shares the oil with the final drive.
For engine oil I use straight 30 weight and capacity without filter is 6 quarts.
For hydraulic oil I use 20 weight hydraulic oil and if you drain the system it will have around 22 quarts or so.Not everyone will agree with this oil choice,Oliver used a additive with 10 weight engine oil but as far as I know the additive is not around anymore.I dont have any problems but i dont use a loader on the 1800.Hope this helps
larry wolfe
07-05-2000 05:10:21
 Re: Re: Oliver 1800 transmission oil in reply to highboyford, 07-03-2000 13:51:13
Late model 1800/s have the transmission and rear use the same oil and only need to be filled at the rear. Fill to the top check plug hole. Amount of oil is similar to early models.
