FLUIDS FOR TRANSMISISON
ED
07-01-2000 06:26:31
CAN SOMEONE PLEASE TELL ME WHAT THE REC. FLUID AMOUNT IS FOR A 880 DEISEL AND WHAT TYPE OR GRADE I SHOULD USE FOR THE TRAMISSION GEAR BOX.HAVE A SERVICE MANUAL BUT NO METION OF IT. THANKS
ED
07-01-2000 08:12:01
 Re: FLUIDS FOR TRANSMISISON in reply to ED, 07-01-2000 06:26:31
scott, thank you for the info.10w-3 it is.ed
Scott Green
07-01-2000 08:06:29
The capacity of your "880" transmission is 4-1/2 Gallons. Use a good quality 10-30 motor oil all year round in the transmission.I use the same in the engine. The older Oliver tractors had a 90-140 gear lube in the transmission. My manual says that when it's time to change the gear lube , put 10-30 in them also.Oliver has some high speed gears in the transmission which require constant lubrication which the 90-140 gear lube is not satisfactory.What ever you do , do not use 90-140 gear lube if your tractor has a power booster drive. The advise I had just given you , came strait from my manual.The manual I have , covers from the fleet line through the 3 didget.
