OC-3 Hercules IXB-3 engine
D B Smith
07-01-2000 05:38:17
Help! Right in the middle of a rebuild! Found piston broken between 1st and 2nd rings. Need new/used piston badly. Engine is a Hercules IXB-3 in an Oliver OC-3 track crawler (1953). Piston is stock, no oversize, 3.25" Diameter, 3 ring grooves, "Zollner Heavy Duty" and "161 Heat Treated" stamped, no other markings. I have tried all the parts places within YT pages and no joy! Anybody got a spare?? This is a working tractor and I got jobs pending.....Thanks!!
D B Smith
07-06-2000 06:02:52
 Re: OC-3 Hercules IXB-3 engine in reply to D B Smith, 07-01-2000 05:38:17
Hey, Thanks to all who responded! I got the part I needed from Landis in PA. Actually, I found THREE sources! Landis seems to have just about anything you need for these little kitty-cats! RAM engine repair in CA also seems to have good sources.
Thanks again!!
Albert Duroe
07-04-2000 21:30:38
Call Landis 717 738 2573 they should be able to help you. I would have a used piston standard but it wopuld not be a Zollner. Good Luck Spark
