1850 Trans/Rearend Oil ?
Brandon
06-29-2000 06:51:53
I am hoping someone can tell me what is the correct oil to use in an 1850 Trans/Rearend? I purchased some universal Trans/Hydraulic fluid at the local farm store. The fluid indicates it will substitute for White Q-1722, JD 303, J20A, IH Hy-Tran, and others. I put it in after draining my old fluid and changing my filter, and then ran the tractor a little bit. When rechecking the fluid level, the fluid seemed foamy and looked like it had air in it. Is this normal, or am I using the wrong fluid? Also, a special thanks to Larry Wolfe for helping me with my PTO problems, check out my latest post to 1850 PTO Problems to hear about what I found.
larry wolfe
06-29-2000 09:35:02
 Re: 1850 Trans/Rearend Oil ? in reply to Brandon, 06-29-2000 06:51:53
The 1850 should have 90 gear oil. Some air will get in the oil,
larry wolfe
06-29-2000 09:41:08
 Re: Re: 1850 Trans/Rearend Oil ? in reply to larry wolfe, 06-29-2000 09:35:02
Water can get into the rear by running down the gearshift lever if the rubber boot is bad.
