Oliver 99 GM
Jason (WI)
06-26-2000 20:58:14
Does anybody know the maximum width of a 99? Oh why not all the diminsions. I may need to haul one for a guy so I need a trailer it will fit one. Thanks ahead of time!
Jason
Scott Franklin
06-29-2000 06:49:03
 Re: Oliver 99 GM in reply to Jason (WI), 06-26-2000 20:58:14
The width depends on the tire size. I have a Super 99 with 23" wide tires and it is 8' wide. A lot of them had 18" wide tires so they would be a little less. None of them will fit between the wheel wells of a car type of trailer. You better find out how much it weighs. Even a striped down light weight one is 8500 pounds. With heavy wheel hubs, extra weights, and ballast in the tires it could weigh 20,000 pounds. You will need a flat-bed goose neck trailer to haul a Super 99 safely and legally.
Dan from PA
06-27-2000 09:52:58
I would think that, depending on how the wheels and axles are set up, a 99 *could* be too wide for almost any street-legal trailer. Better measure the actual tractor. Barring that, better get a trailer that you can hang a bit off the edges.
Weight will probably be in excess of 5t.
