Oliver 55 PTO Problem?
Stewart
06-18-2000 18:31:26
I was using the PTO with a 5 foot bush hog. After a while I noticed that the PTO wasn't giving as much power and I was losing RPM's on the hog. Can I make a Adjustment and how do I do that. Thanks in advance .
Dan
07-09-2000 20:01:16
 Re: Oliver 55 PTO Problem? in reply to Stewart, 06-18-2000 18:31:26
I am having a problem attaching a bush hog to my super 55. the mower seams too close to the rear wheels and the three point arms allow the bush hog to swing from side to side into the tires. Any ideas on hpw to remedy this.
larry wolfe
06-19-2000 09:11:15
Their is a plate under the tractor center section that can be removed to adjust the pto clutch. Push in the spring button and turn clutch tighener. You do have to work with big screwdrivers.
stewart
06-19-2000 14:21:22
 Re: Re: Oliver 55 PTO Problem? in reply to larry wolfe, 06-19-2000 09:11:15
I will give it a try tomorrow thanks.
stewart
07-22-2000 09:28:28
 Re: Re: Re: Oliver 55 PTO Problem? in reply to stewart, 06-19-2000 14:21:22
Thanks to all ,Im back in business.
