S88 carb ice
Dan from PA
06-17-2000 21:42:24
Has anyone ever had trouble with ice building up in the carb throat? I have a Super 88 with the Zenith carburator and it doesn't happen very often, only a couple of times in the past 10 years or so. But with these not-too-hot (70's and 80's) but really humid (95-100%) days we've been having for the past week or so, the tractor's been almost unusable. It'll run fine for 45 minutes or an hour, but then sputters and dies. You can play with the choke to keep it running, but it has no power. When you look at the carb, it's covered with frost, and if you let it sit for a while water (not gas) starts to drip out of it.
I've checked the sediment bowl for water, found none, but added a bottle of dry-gas anyway. No change.
I know carburated airplanes have this trouble, and they are equipped with a system that circulates heated air into the intake.
Will re-building/replacing the carb help? This isn't a super-big problem, but I was wondering if anyone has run into it before.
Thanks in advance.
John
06-18-2000 08:03:02
 Re: S88 carb ice in reply to Dan from PA, 06-17-2000 21:42:24
I have several Olivers that occasionally have this problem. Most often with S88 and 1650 gas. I keep a couple of sheets of galvanized tin around. When this happens, just wedge the tin up under hood, around carb and down behind cast frame. It traps enough heat to eliminate the ice until the offending weather changes. Be careful that the tin does not contact the "hot" terminal on your starter. By the way, I would guess that the problem has something to do with unleaded gas, lower octane than engine was designed for and perhaps intake leaks common with the age of the machines.
Dean
06-18-2000 05:30:24
It's perfectly normal for ice to accumulate on the outside of a carburetor under the conditions you describe and does not necessarily indicate the presence of ice on the inside of the carburetor. If the tractor runs for 45 to an hour before it quits, it's not likely that icing is a problem. I would try draining the float bowl on the carburetor to remove any water that may be present. Condensation forms inside the gas tank rather quickly under those weather conditions and can overwhelm the sediment bowl. Next I would check to make sure there is no crud in the gas tank and gas lines. Lack of a proper gas tank vent (gas cap?) could be a cause too. Good luck!
