Super 88 Battery
delmer
06-14-2000 09:45:35
Howdy,
I have a 57 Super 88 (gas) and was wondering if anyone knew the amperage of the (original) factory battery for this model. I had a 625 in it, and it just wasn't turning over; what is the highest amperage I can safely go?
Thanks.
delmer
06-16-2000 10:50:35
 Re: Super 88 Battery in reply to delmer, 06-14-2000 09:45:35
Put the 950 in it and it works fine, think I just had a battery that was bad, replaced it with a new battery that I believe had a short.
works great now, thanks.
Delbert
06-15-2000 15:30:47
Without looking in the book to be sure, some olivers are POS ground, that could be some of the problem. A high amp battery will not be a problem if it fits in the battery box. Delbert
Dick L
06-14-2000 11:36:53
You can go as high as they make them. Thats probably not your problem. Could be the starter needs rebuilt, could be bad connections on wire ends, could be to small of battery cable. could be a weak battery, but if it is new and up to full charge a 625 would work.
