Oliver Crawler where is the ser. no. I.D.?
Obie
06-05-2000 09:11:56
I just bought a Oliver Crawler with a front end loader and can NOT find the I.D.plate?? The seller said it was a OC3??? BUT I looked high and low and cant find any info on the loader or the tractor or engine.Can any one please tell me where the I.D. plate should be located cause I need pistons for the engine.. THANKS Obie
Albert Duroe
06-05-2000 19:40:50
 Re: Oliver Crawler where is the ser. no. I.D.? in reply to Obie, 06-05-2000 09:11:56
On the OC-3 loader crawler most of the serial # plates are gone. The motor has a serial number plate on the side. It would be and IXB3 Hercules motor but you would have to pull the old pistons or measure the bore to see if your pistons are oversized. Email me if you have any other questions. Good Luck Spark
