Oliver steel wheel 4 bottom plow
Dave Preuhs
05-24-2000 14:47:59
I have an Oliver 4-16 steel wheeled plow with the 2 large cranks for leveling instead of handles. What color was this plow painted. Was the the whole thing red with yellow wheels. Was there any blue trim anywhere. Or were the wheels green. Someone knows out there in cyberland. Thanks.
DKaiser
05-29-2000 15:41:52
 Re: Oliver steel wheel 4 bottom plow in reply to Dave Preuhs, 05-24-2000 14:47:59
third party image
The plow could either be red or greeen with yellow wheels. I think all steel wheel plows had yellow wheels regardless of color. Depending on its number it may have had green and yellow trim around the plow. I did paint a 4 bottom last year that was red and had green wheels because it uses rubber tires. If I knew what type of lift it had and what the hitch looks like I could tell you more. The plow could be either a 274,284,384, or a 414.
Adam
05-28-2000 11:47:22
I haven't seen one yet but I'll ask around for you. You got a hart parr big enuff to match up to it? Hope spring work went or is going well.
You can guess :)
05-24-2000 21:37:26
I'd tell you for a skillet full of sausage and fried potatoes!!
