OC-3
NW
12-02-1998 20:34:31
I just located a 0C-3 with a henderson loader. I noticed the drive sprocket rubs the final drive housing. what does it involve to correct this? is there a bearing or bushing that needs to be replaced? also some of the track rollers are in bad shape. other than that, and needs a little paint, it is in good overall condition. I am concidering to buy it if parts are available to fix it. What would i expect to pay for a gem like this? thanks for any help.
Bill Wesche
12-13-1998 17:47:02
 Re: OC-3 in reply to NW, 12-02-1998 20:34:31
I have an OC4. I know were you can locate some parts for your OC3. I am rebuiding my OC4. Tracks- to be re bushed and re pinned is around $1000.00. Please reply if interested.
NW
12-19-1998 06:05:06
 Re: Re: OC-3 in reply to Bill Wesche, 12-13-1998 17:47:02
altough the track is not real bad , i cant say they arent worn. i may want to rebush,repin later on in the restoration.where can this be done? can a large machine shop do this procedure? thanks
martin
12-24-1998 16:32:38
 Re: Re: Re: OC-3 in reply to NW, 12-19-1998 06:05:06
I've got an )C-3 that the previous owner had new sealed Case bearings in the track rollers. Seems to work great and I don't have to oil them all the time. I'm not sure what size of Case bearings they were, though.
~martin
Bill Wesche
12-13-1998 17:42:07
: I just located a 0C-3 with a henderson loader. I noticed the drive sprocket rubs the final drive housing. what does it involve to correct this? is there a bearing or bushing that needs to be replaced? also some of the track rollers are in bad shape. other than that, and needs a little paint, it is in good overall condition. I am concidering to buy it if parts are available to fix it. What would i expect to pay for a gem like this? thanks for any help.
scott
12-18-1998 03:30:02
 Re: Re: OC-3 in reply to Bill Wesche, 12-13-1998 17:42:07
The OC3 has two cone barrings inside on the bull gear. allso has two of them on the small gear that runs it. Its not that hard to fix if you do it yourself you can get out of it for around 100.00 Good luck Scott
