Oliver 880
Moosie
04-22-2000 06:08:15
Am interested in a 880 for sale. It is a nice tight tractor. Are they a good restoration project? Any weaknesses etc.? Will be used to do light work around home. (Yes, I like the horsepower, other wise I would get a 2N or something.) Thanks.
highboyford
04-22-2000 20:38:50
 Re: Oliver 880 in reply to Moosie, 04-22-2000 06:08:15
Well if you are only going to do light work you should consider another tractor :)But if you must have it it is a good choice.plenty of power and has good fuel economy.Things to look for --use a hydraulic cylinder to make sure the pump is ok.Also the power booster has two clutches(about $90 each) that the inside teeth could wear out and cause the tranny to kick out on the lower gears.Only real way to check is to pull a load but even if they are bad are not a high dollar item to fix.Otherwise I do not know of any other problems with these tractors.
Dale (MI)
04-26-2000 13:11:19
 Re: Re: Oliver 880 in reply to highboyford, 04-22-2000 20:38:50
Will that same power booster problem happen in 770s? Dad's got one with a problem.
highboyford
04-26-2000 17:32:56
 Re: Re: Re: Oliver 880 in reply to Dale (MI), 04-26-2000 13:11:19
Yes I spose it could happen because your dad actually owns it you could always tear into it and check it out.
