Oliver 77 to 770
Dick
04-20-2000 11:35:05
I would like to put a Oliver 77 gas engine about 1952 into a 770 Oliver diesel loader backhoe. The diesel thru a rod. I couldn't find a used engine, but I did find a 77 gas engine.I don't need the fuel economy of the diesel as this is just a farm tractor. Besides I had trouble starting the diesel in cold weather. the rest of the tractor is in good shape.What kind of problems will I run into,and is it possible? Thank you.
Kevin Coers
04-20-2000 15:32:08
 Re: Oliver 77 to 770 in reply to Dick, 04-20-2000 11:35:05
i did that also, the only trouble i ran into was with the steering shaft, i had to place a piece to make the shaft stick out about 1" from the original position
Dick
04-21-2000 07:51:34
 Re: Re: Oliver 77 to 770 in reply to Kevin Coers, 04-20-2000 15:32:08
Thank you, That gives me a lttle more confidence.
Dick
