What is an 88F row croper worth???
Bill
04-19-2000 18:11:32
I need to know what a 88F row croper is worth. This tractor has the following;
Tricycle configuration.
PTO, but does not work.
Fuel is gas
3 point hitch.
Rubber poor.
Had water in gas tank at one time.
Starter button has been replaced with an auto dimmer switch.
Steering wheel cracked and seperated.
Side panals are missing.
Gas cap gone.
Over heats when running, some times.
Paint in good condition, older repaint job.
very little rust.
Reported to run but battery was dead when trying to start.
Owner says that tractor was not running when he bought it. Mechanic that worked on it, shorten the drive shaft.
Brakes unknown.
Dash light missing
Lights on fenders unknow if they work.
Transmittion reported to be good.
If anyone has any information on what this tractor would be worth, Please let me know. Thanks.
mwn
04-20-2000 17:08:10
 Re: what is an 88F row croper worth??? in reply to Bill, 04-19-2000 18:11:32
Bill, you have a couple ways to look at this unit. 1.)determine the cost of all the parts needed to get the tractor into the condition you desire and ask yourself what the base unit is worth to you. or;
2.)determine which parts may be of value, then determine the value of the parts.
Sounds like it needs quite a bit of work, but then again, a little work may get you a useable tractor. Try visiting the photo adds and auctions in an effort to gather comparable value information. Your efforts there will be much more valuable than an opinion of someone who has never seen the tractor. Good luck.
Mark
steve
04-20-2000 06:10:45
 Re: Re: what is an 88F row croper worth??? in reply to Nobody, 04-20-2000 00:21:21
your statistical analysis and insightful commentary are truly inspiring and accurate!!
steve
oily
04-20-2000 08:37:05
 Re: Re: Re: what is an 88F row croper worth??? in reply to steve, 04-20-2000 06:10:45
what the #%$@ is a 88F
