1650 clutch repair advice needed
Kevin D.
11-29-1998 09:03:02
Two questions: 1. I have to replace the clutch on a 1650. I have a shop manual (I&T Shop Service) but more technical detailed information is needed. Advice and instruction greatly appreciated. This is a gas unit and is equipped with hydra-drive
2. Where do I look for a serial number? I have found numbers on left side of block above starter. Top # 159004-A, below that is 19062OB and below that is 1274. Are these serial numbers or casting numbers?
John H.
11-29-1998 17:49:40
 Re: 1650 clutch repair advice needed in reply to Kevin D., 11-29-1998 09:03:02
: Two questions: : 1. I have to replace the clutch on a 1650. I have a shop manual (I&T Shop Service) but more technical detailed information is needed. Advice and instruction greatly appreciated. This is a gas unit and is equipped with hydra-drive
: 2. Where do I look for a serial number? I have found numbers on left side of block above starter. Top # 159004-A, below that is 19062OB and below that is 1274. Are these serial numbers or casting numbers?
John H.
11-29-1998 18:30:37
 Re: Re: 1650 clutch repair advice needed in reply to John H., 11-29-1998 17:49:40
Two bits of advice; first be sure to remove the PTO driveshaft, there is a cast iron cover above the PTO shaft at rear of tractor it is held on by 4 bolts coming up from the bottom. next remove 3 bolts holding brg. flange on shaft, they are behind PTO clutch, will need to use an end wrench to get them out. next when you remove the 4 bolts holding the engine down, two of them are dowel or alignment bolts and will need to go back in the same holes. two of the head bolts are used for lifting they have threads sticking up on top, use the one to the rear to lift the engine and hydra-power,if someone hasn't put them in the wrong holes it should be balanced. good luck!
: : Two questions: : : 1. I have to replace the clutch on a 1650. I have a shop manual (I&T Shop Service) but more technical detailed information is needed. Advice and instruction greatly appreciated. This is a gas unit and is equipped with hydra-drive
: : 2. Where do I look for a serial number? I have found numbers on left side of block above starter. Top # 159004-A, below that is 19062OB and below that is 1274. Are these serial numbers or casting numbers?
