Olive 1755 PTO Problem
James
04-18-2000 20:08:44
On april 5th I put a message in here about not being able to get my PTO to engage all the way. So I took the PTO housing off and was going to replace the clutch plates. Well nothing was wrong inside, the problem was in a shift rod on the bottom of the housing that could be moved for 1000 rpm or 540 rpm that I didn't know about. It was in the middle of the two setting. WOW !!! I pulled it out and it engaged just perfect. Well at least I know more about my Oliver!! Thank all of you that responded to my call for information. My original message is on page 4 or 5 now. Thanks again, James
mark
04-19-2000 16:48:55
 Re: Olive 1755 PTO Problem in reply to James, 04-18-2000 20:08:44
isn't it the case that you figure more out about something by taking it apart? glad you didn't find problems.
