Oliver 60 haybaler
Rob
04-14-2000 07:19:11
I have an Oliver 60 twine baler from the late 1950s. It has a Wisconsin engine on it that is worn out. The same model baler was also made with a PTO drive. I need the slip clutch assembly that bolts onto the flywheel with three bolts to drive the baler from the PTO. If anyone knows where I can get this part either new or used please let me know.
The baler is green with red wheels and yellow decals, if that helps determine the age. Anyone know when Oliver went to green and White?
kp
04-18-2000 19:18:16
 Re: Oliver 60 haybaler in reply to Rob, 04-14-2000 07:19:11
Hi rob
I have a 60 baler that is in pretty good shape for parts I will let you have it for $50.00 you pick it up. I'm in Northeast colo.Let me know.
Rob
04-21-2000 11:00:08
 Re: Re: Oliver 60 haybaler in reply to kp, 04-18-2000 19:18:16
Thanks for responding but I am in Southeast VA. How much do you think the part weighs? Is small enough to be shipped by UPS?
Tracy
04-16-2000 21:22:20
Hey Rob, was at the salvage yard the other day and noticed an old oliver baler, i,ll check it out in a couple days when i go back, I also know where there is two more, I,ll have to check them out also, Tracy.
Rob
04-18-2000 10:32:22
 Re: Re: Oliver 60 haybaler in reply to Tracy, 04-16-2000 21:22:20
Thanks, let me know what you find.
