Oliver 70 engine
Tim
04-02-2000 06:55:00
I have an oliver 70 that has a kaiser frazer engine in it. It has same mounts as the original engine would have. Has same stroke but has a slightly larger bore than the continental engine that would normally be in this tractor. I'm wondering if this engine was made for this tractor. Any help would be appreciated. Thanks.
highboyford
04-03-2000 21:21:26
 Re: Oliver 70 engine in reply to Tim, 04-02-2000 06:55:00
Didnt some kaiser/frasier cars use continental engines.That would explain why the bolt pattern is the same.I have never owned a 70 but as far as I know only the one engine(in different versions)was offered.I agree with the others old engine was shot and they just repowered it,I would like to know what the tractor pulls on the dyno,interesting to see how much hp it has.
Delbert
04-03-2000 20:41:21
The engine in your tractor is most likely a repower. During and after the 2nd world war farm equipment was in verry short supply, a bad engine may not have had parts available so many tractors were repowered with auto or other engines that could be instslled easily. I have an oliver 70 with a Buda diesel, the frame had to be modified a great lot. Oliver never built their engines, if I remember correctly Continental and Waukasha built engines to Oliver specs. The Hart-Parr 70 had a five gear timing gear arrangement, the early Fleetline 70 tractors had the five gears also, the later Fleetline 70 had a three gear timing arrangement these tractors had the magneto or the distributor on the opposite side of the sparkplugs,they had a different govenor and probably some other small differences. As for the repower tractors, I tried to buy a 70 with a Chevy truck engine. The owner said his Uncle gave it to him to start farming with. He also said the tractor pulled a three bottum plow with no problem.
Marvin
03-10-2002 08:58:54
 Re: Re: Oliver 70 engine in reply to Delbert, 04-03-2000 20:41:21
On a model 70 Oliver what is the advantage or disadvantage of having a 3 gear or 5 gear motor?
Scott Green
04-04-2000 09:52:49
Delbert , don't forget , when it comes to the waukesha engine , Oliver casted the blocks along with some other parts.They then shipped the blocks to Waukesha for the internal machining work.McCoy Truck Lines did the trucking for them.
larry wolfe
04-02-2000 07:24:02
70,s came from factory with 2 differnt engines.Also one engine had 2 versions one with magneto on the left one with distbutor on right.
george
11-28-2003 15:00:58
 Re: Re: Oliver 70 engine in reply to larry wolfe, 04-02-2000 07:24:02
will some tell me where Ican find exhaust valves for my 70 oliver if any help my dist is on r side of motor. any help is appericated greatly.
Scott Green
04-02-2000 08:45:59
Larry , The only engines in the Oliver model "70" tractors that I have seen or read about is the continental engine.But , the continental engine in the standard tractors do have a different design to it , compared to the row crop tractors.Are you saying that the Oliver "70" had two different engine makes , or two different continental engines.If a different make , fill us readers in.We are all interested in what you have to say. Scott
Karl in MD
04-02-2000 17:16:05
 Re: Re: Re: Oliver 70 engine in reply to Scott Green, 04-02-2000 08:45:59
Scott, I didn't know the RC and STD had differences in the engine, can you give details? I had a Hart Parr 70 with a magneto and it was mounted on the right side of the engine. It used a different governor and timing case, but was the same basic engine as the other 70s we have had.
Scott Green
04-03-2000 03:11:54
 Re: Re: Re: Re: Oliver 70 engine in reply to Karl in MD, 04-02-2000 17:16:05
Karl , I should have made my self more clear.I was talking about the front casting (governor area) of the engine , not the basic engine.Larry was talking about a complete different engine.I have not ever seen or read about a complete different engine in the Oliver "70" tractor.It has always been the continental engine as far as I know.Larry should fill us in if he knows of a complete different engine that was installed from the Oliver factory (maybe an experimental) Scott
larry
04-03-2000 09:58:49
 Re: Re: Re: Re: Re: Oliver 70 engine in reply to Scott Green, 04-03-2000 03:11:54
I wrote it down wrong. You guys are right. A guy near here has 2. the engines look differnt one has the sparkplug wires waraping around rear of engine. the other they stay on one side.
larry
04-03-2000 10:15:00
 Re: Re: Re: Re: Re: Re: Oliver 70 engine in reply to larry, 04-03-2000 09:58:49
I may be wrong about that.
Tim
04-04-2000 20:16:38
 Re: Re: Re: Re: Re: Re: Re: Oliver 70 engine in reply to larry, 04-03-2000 10:15:00
Thanks for all the input. I guess kaiser frazer must have made an engine that would fit in this tractor. Haven't got it running yet but hope to soon. Thanks again.
