Oliver 77, Missing S/N. Do you know the year of this tractor?
ROD HERGOTT
11-15-1998 09:01:36
I have an Oliver 77 standard with factory hydraulics and LPTO. The serial number plate has been destroyed by someone scratching it to hard with a wire brush. I would like to know the year of this machine. Can anyone help me?
e jensen
11-15-1998 19:28:48
 Re: Oliver 77, Missing S/N. Do you know the year of this tractor? in reply to ROD HERGOTT, 11-15-1998 09:01:36
: I have an Oliver 77 standard with factory hydraulics and LPTO. The serial number plate has been destroyed by someone scratching it to hard with a wire brush. I would like to know the year of this machine. Can anyone help me?
Under the frame are cast marks giving the month and year that the frame was cast. This is probably as close as you will come
rod
11-17-1998 20:31:01
 Re: Re: Oliver 77, Missing S/N. Do you know the year of this tractor? in reply to e jensen, 11-15-1998 19:28:48
: Someone provided the suggestion that under the frame, the year and date would be recorded. Where on the frame would this be? Thanks again
: : I have an Oliver 77 standard with factory hydraulics and LPTO. The serial number plate has been destroyed by someone scratching it to hard with a wire brush. I would like to know the year of this machine. Can anyone help me?
: Under the frame are cast marks giving the month and year that the frame was cast. This is probably as close as you will come
Dennis H.
11-20-1998 16:17:33
 Re: Re: Re: Oliver 77, Missing S/N. Do you know the year of this tractor? in reply to rod , 11-17-1998 20:31:01
: : Someone provided the suggestion that under the frame, the year and date would be recorded. Where on the frame would this be? Thanks again
: : : I have an Oliver 77 standard with factory hydraulics and LPTO. The serial number plate has been destroyed by someone scratching it to hard with a wire brush. I would like to know the year of this machine. Can anyone help me?
: : Under the frame are cast marks giving the month and year that the frame was cast. This is probably as close as you will come
Look under the tractor where you drain the gear oil from the transaxel, the date will be in raised numbers cast right in the metal. Take a wire brush with you and maybe a putty knife if it's covered with goo.
rod hergott
11-25-1998 18:19:59
 Re: Re: Re: Re: Oliver 77, Missing S/N. Do you know the year of this tractor? in reply to Dennis H., 11-20-1998 16:17:33
: : : Someone provided the suggestion that under the frame, the year and date would be recorded. Where on the frame would this be? Thanks again
: : : : I have an Oliver 77 standard with factory hydraulics and LPTO. The serial number plate has been destroyed by someone scratching it to hard with a wire brush. I would like to know the year of this machine. Can anyone help me?
: : : Under the frame are cast marks giving the month and year that the frame was cast. This is probably as close as you will come
: Look under the tractor where you drain the gear oil from the transaxel, the date will be in raised numbers cast right in the metal. Take a wire brush with you and maybe a putty knife if it's covered with goo.
I found the year by looking at the frame. It is a 1951. Thanks for your help in finding it everybody.
rod hergott
11-25-1998 18:19:32
