550 Oliver forklift
Albert Duroe
03-29-2000 04:23:53
I just purchased a 550 forklift and I can find only one forward gear after it was unloaded do the shifting forks get worn and how do I correct the problem? The machine needs some TLC but it runs good and should be able to pick up those little HG crawlers. Thanks Spark
larry wolfe
03-31-2000 09:28:11
 Re: 550 Oliver forklift in reply to Albert Duroe, 03-29-2000 04:23:53
The shift forks can break off this alows half to fall into bottem of trans and rub against gears.Aufull noise. When this happens you lose 2gears in each range a total of 4. 6-4=2which is what you have. Remove hyd unit or (cover )in your case and weld the fork togather.
larry
03-31-2000 16:24:43
 Re: Re: 550 Oliver forklift in reply to larry wolfe, 03-31-2000 09:28:11
The forks must hold shift collers corretly or they will bind. Before bolting down top make sure they shift easily. IT took me three trys to get corect.
Gary Hearn
03-30-2000 19:09:51
Spark-
I have a 1962 551 forklift and it has the standard 6/2 transmission. I think that I have heard that some has a shuttle type shift similar to that found on backhoes. Could yours be one of those?
Mike
03-30-2000 16:59:49
Your 550 forklift has a lifting capacity of 2 tons.
Mike
