Oliver 770 puller -Update ( Torque amplifier?)
Dan Johnson
11-08-1998 17:03:19
Thanks Gary, Terry and Bob for your input, I bought the tractor and find that it has a lever to the left of the dash that seems to be a High/low or a torque amplifier of some sort. Is anyone familiar with what this is and what ratio it reduces. I have never seen one on an Oliver. Please let me know what I have. Thanks again. Dan
Gary Hearn
11-09-1998 20:22:42
 Re: Oliver 770 puller -Update ( Torque amplifier?) in reply to Dan Johnson, 11-08-1998 17:03:19
You have the Hydra Power system that allows for 12 forward speeds and 4 reverses. It was later followed by the Over/Under system that had a low and high range off the normal direct drive.
My memory is that it provides about a 20% reduction in ground speed.
Gary
: Thanks Gary, Terry and Bob for your input, I bought the tractor and find that it has a lever to the left of the dash that seems to be a High/low or a torque amplifier of some sort. Is anyone familiar with what this is and what ratio it reduces. I have never seen one on an Oliver. Please let me know what I have. Thanks again. Dan
john
11-10-1998 08:41:39
 Re: Re: Oliver 770 puller -Update ( Torque amplifier?) in reply to Gary Hearn, 11-09-1998 20:22:42
Your 770 does not have a hydra power drive, it has a power booster drive. The hydra power drive is hydraulically operated while the power booster drive is a manual clutch.
: You have the Hydra Power system that allows for 12 forward speeds and 4 reverses. It was later followed by the Over/Under system that had a low and high range off the normal direct drive.
: My memory is that it provides about a 20% reduction in ground speed.
: Gary
: : Thanks Gary, Terry and Bob for your input, I bought the tractor and find that it has a lever to the left of the dash that seems to be a High/low or a torque amplifier of some sort. Is anyone familiar with what this is and what ratio it reduces. I have never seen one on an Oliver. Please let me know what I have. Thanks again. Dan
