Super 55???
Jim Rizzi
03-18-2000 15:56:14
I have an Oliver tractor that I believe is a Super 55. The serial # is 60-965-519. I understand that the last three numbers indicate the model. Can anyone please help? Thanks.
D13
03-20-2000 09:47:08
 Re: Super 55??? in reply to Jim Rizzi, 03-18-2000 15:56:14
The three numbers after the dash indicate the equipment the tractor was built with, specifically the gearing in the trans and rear end.
Danny Yerks
03-20-2000 07:15:48
It's a 1958 model, but I don't know if it's a Super 55 or 550. That was the year they transitioned from the Super 55 to the 550 and they are very hard to tell apart until they changed the grill some years later. All of the Super 55's I've seen have a metal grill with horizontal slots and the serial number ends in 518. All of the 550's I've seen have a plastic/fiberglass grill with square openings, but I think the first couple of years they made the 550 they used the same type of grill as the Super 55. On all the 550's I've seen the serial number ends in 019, but they were all low to mid 60's models. Maybe they used the 519 for the last 3 numbers during the transistion year. If it has the original paint, a Super 55 had red wheels and a 550 had white ones, but someone might have changed the wheels. If you email me some pictures showing the locations of PTO and 3pt lift levers and what the dash looks like, I might be able to compare it with some pictures of Super 55's and 550's and be able to tell you more. I'm as curious as you are now!
Jim Rizzi
03-23-2000 14:51:20
 Re: Re: Super 55??? in reply to Danny Yerks, 03-20-2000 07:15:48
Thanks for the responses. I will work on e-mailing pictures to those interested. My tractor has a metal grill with horizontal slats and a plastic oval "OLIVER" emblem at the top. As for the wheels, they are and were white when I bought it. Unfortunately the person who sold me this tractor moved to Alabama and I dont have his address to ask him more. Another note is that the nomenclature plate is located on the left side, level with the clutch pedal. The exhaust and air breather go up through the hood. The engine is a four cylinder and the dipstick says "high" and the number 55 stamped on it. Hope this helps with any more info you all might have. Thanks again.
Kerry
03-20-2000 14:17:40
third party image
Go to this www page and you will see a 550 with a metal grill. According to my 550 Parts Catalog This is the grill that was used on the 550 from s/n 60 501 - 122 957 from 122 958 and on they used a plastic grill.
http://www.ytmag.com/cgi-bin/gallery/photo_pic.cgi?pic=http;//www.ytmag.com/gallery/oc05-020.jpg&firstrec=1&lastrec=15&Parameter=oliver
Kerry
03-20-2000 06:00:01
I think that it is a 1958 550.
Paul Stanley
03-19-2000 20:36:52
If it is a Super 55 it is a 1958. The last three numbers don't indicate the model, but I don't know what they do stand for. The last 3 on my Super 55 are 518 if I remember right. What does your tractor look like? Is it a utility as compared to a row crop? Four cylinder engine? Describe your tractor or go to the photo gallery on this site and look up Super 55, there is a good picture of one there. Let us know what you discover. Need more help, email me.
