WHITE/OLIVER 38" RIMS
Hal S.
11-05-1998 08:05:38
I have a White 2-70 with 38" steel rims (13.6x38 tires) and cast iron centers; I assume this is similar to some Olivers. The rims have 2 rails on the inside surface which are used to attach to the cast center via 8 cast step lugs. There are 4 locating tabs for the step lugs on the rails, 2 on each side of the valve stem hole 45 degrees apart. The other 4 lugs do not have a locating tab, they just lock against the rail. My question is, what is the correct procedure to remove/install the rim/tire from the tire? Should the valve stem and the locating tabs be at the top or the bottom? Is it necessary to loosen all 8 lugs, or possibly only the 4 opposite the valve stem? Thanks for any advice.
Hal S.
11-05-1998 08:09:33
 Re: WHITE/OLIVER 38" RIMS in reply to Hal S., 11-05-1998 08:05:38
There is a typo in the above post; I meant to say "remove the rim/tire from the TRACTOR", not from the tire.
