Options your tractor has?
highboyford
03-16-2000 20:47:12
What Options are out there?Does anyone have a s88 with 1000 pto?Or a 880 with 1000?What about a standard 77 with 3-point?Extra hydraulic tank mounted on your 880?Dual tip toe wheels on your 70?Extra wide axle for duals on a 88?side hill hitch on a s88?what about a 1800a with a crawler tranny and a 1000 pto?anyone have the "el torro"?lets keep it to options offered by Oliver(ie not step plates on a s88,they are not factory)Anyone have a s88 with a hand clutch?Or a 88 with the 302 waukesha engine (super 99 6 cylinder) story has it that a dealer in southern Illinois built a bunch of these(would call that a major field option)thanks waiting to see what is out there yet.
larry h
03-19-2000 11:56:46
 Re: Options your tractor has? in reply to highboyford, 03-16-2000 20:47:12
we have an oliver 770 with lp fuel wide front wheatland metal fender extensions three point and wts
H
03-19-2000 10:39:22
In the mid 50's my Dad bought a new super 88 and had the dealer install a super 99 gas engine in it. The dealer then put the super 88 engine in our 77. I think both tractors used industrial clutches and 6 bladed fans. They were very neat installations. Hard to tell they were't factory built.
highboyford
03-19-2000 19:27:40
 Re: Re: Options your tractor has? in reply to H, 03-19-2000 10:39:22
Hee Hee I bet they showed the bear how to eat cabbage!Any idea what happened to them or do you still have them?
B A Star
03-17-2000 20:03:37
Highboyford: Thought that I might meet you at Waterloo. We had a great time. If any of you were there, I presented the tech session on Moldboard plows. I have a 660 with the Hyd. landing hitch. It is the 58th one built. bought it near Topeka, Ks was used to build terraces in that area.
Chris Losey
03-17-2000 19:26:46
My neighbors have a Fleetline 88 with the low speed rear end and the 1000 rpm pto.
Jerry B
03-20-2000 17:04:54
 Re: Re: Options your tractor has? in reply to Chris Losey, 03-17-2000 19:26:46
I would like to have a low speed rear end for my 77. Know where I can find a gear set? Are the 77 and 88's the same gears? thanks
Jerry B
03-20-2000 17:04:37
Chris Losey
03-21-2000 20:12:05
 Re: Re: Re: Options your tractor has? in reply to Jerry B, 03-20-2000 17:04:37
I think they are different gears. I don't know of any for sale at this time. Sorry.
Karl in MD
03-17-2000 18:26:25
I've wondered why every Fleetline 77 in my neck of the woods has a #3 Hydra-Lectric unit which, according to the parts books were only available on the supers??
highboyford
03-17-2000 20:32:23
 Re: Re: Options your tractor has? in reply to Karl in MD, 03-17-2000 18:26:25
Karl what do you mean by #3 Hydra-lectric?If you mean what i am thinking the 77 could have a factory installed Hydra-lectric for both mounted and remote controlled(pull type)and then also had a field conversion for another remote controlled(pull type)equipment.Which doesnt sound right because I have only seen single or dual hydraulic pump controls so you would then have more lectric controls than valves.
Karl in MD
03-18-2000 16:31:41
 Re: Re: Re: Options your tractor has? in reply to highboyford, 03-17-2000 20:32:23
By #3 I mean the third change level of the Hydra-lectric as defined in the I&T manual. The units were available as straight manual (lever) control, straight hydraulic (switch) control or both together. The earlier units, (#1 and #2) had the levers mounted on stub shafts on the sides of the reservoir, while the later (#3) units had the levers on the top cover with those blessed Oliver leaky rubber boots so that rainwater can run directly into the reservoir.
B A STAR
03-18-2000 18:10:02
 Re: Re: Re: Re: Options your tractor has? in reply to Karl in MD, 03-18-2000 16:31:41
Karl: These unit were under catalouge # F40. Most company and dealer people thus called them by the F40 name.
Karl in MD
03-17-2000 19:33:38
also one of the 77s I have has fender extensions, and a cylinder bracket on the right fender. And why do some Fleetlines have stamped front wheels and some have cast hubs with removable rims? And does anyone have a fleetline with stamped rear wheels? I've seen them in books but not on any tractors around here. Oh, and my 1955 didn't have fender tanks.
Adam
03-17-2000 05:47:52
I have a 3150 engined 2255 with MFWD, factory option 9 bolt hubs for duals and factory option rops canopy, 1650 hydra power diesel with high speed trans goes 22 mph. Dad has a 1950-T with extra heavy duty cat III 3 pt, 1800 B with 1000 rpm pto I don't know if thats uncommon or not. Nothing special about the others. Once had tried a 1850 Hydrolic Front wheel assist wasn't worth a darn compaired to MFWD. Also once had a 2150 MFWD and a 1955 MFWD.
