S77Diesel controls
Earl
03-16-2000 19:39:25
I just got my operators manual for my S77 today when I noticed some things about my tractor which I believe are "field motifications". This is my first oliver tractor to restore and I was wondering if any of you could answer a few questions for me so I'll know where to begin on getting this ol' girl back to it's original condition. First of all the tractor is started by pushing on the belt pulley control at the bottom left and it doesn't even have a place for a key. Did any ever come from the factory like that? Second,on the diesel cut off it seems that the previous owner has bypassed it and has rigged it to where all you have to do is to move the governor lever to the top notch and it will shut off. Again, did any come from the factory like this or was this a field motification? Finally, on the hydraulic. I have the Hydra-lectric type. I wanted to use this tractor to make beds for the garden. Can I just go to any Farm supply and buy a hydraulic cylinder or does it have to be a special cylinder? The reason I am asking this is because I noticed that those two electric cords have something to do with the hydraulics from what I can gathe . Also what else do I need to hook up the front mounted equipmen? One more thing I forgot. Did all S77 come with a tachometer. Thank you , this will help alot getting this cleared up.
jld
03-17-2000 16:35:11
 Re: S77Diesel controls in reply to Earl, 03-16-2000 19:39:25
Have 88D which is same for starting. The lower left rod pedal actuates the starter. If tractor has belt pulley, there is another rod directly above the starter rod. Yes, there originally was a fuel shut off cable on the lower right of the dash (you probably have an empty hole where the cable was removed) but has had the throttle rod adjusted to provide shut off. If equipped with Hydra-lectric, there was another switch on the dash to the left of the fuel shut off (this turned on power to the hyd since tractor does not have a key or master switch (doesn't need one because volt reg cutout is the disconnect). I always park in neutral and lock the brakes because there are no safety switches of a 50's tractor!
highboyford
03-16-2000 19:58:00
Never owned a s77 but have a couple s88 and outside of the gaser all of the diesels I have start with the foot control which by the way is seperate from the belt pulley control(or should be anyway)On the pump shut off - I think that the fuel is just slowed down to a rate where the tractor wont run,would be kind of a pain to hook the shut off up to the throttle lever,also guess cable shut off froze up or link chain broke off pump.Any hydraulic cylinder will work,but you would need a oliver cylinder if you wanted to see if the hydra-electric works(ran Olivers along time and never did run one that had the hydra- lectric working)What kind of front mounted equipment? -loader?you would need brackets that belong to the loader,same if you wanted to use a culitvator.No the tach did not come on all of the tractors-it is a nice option.Good luck
Scott Green
03-17-2000 05:54:52
 Re: Re: S77Diesel controls in reply to highboyford, 03-16-2000 19:58:00
Highboyford , Is your foot control start electric?I had sean a picture along with reading an artical about Oliver custom producing a non electric starting system for some of the fleetline diesel tractors.I don't quite remember , but for some reason , electric could not be used.I believe Oliver used a hydraulic starting motor.You had to pump up preasure useing a hand lever.Then releasing the preasure would spin the starter motor.Is this the foot control start you have? Just wondering , Scott Green
highboyford
03-17-2000 15:22:57
 Re: Re: Re: S77Diesel controls in reply to Scott Green, 03-17-2000 05:54:52
I have seen the story you are talking about,it is in some mass produced Oliver book.Thought the story went that 50 hydraulic hand pumps with accumelators(sp)were built for export to Brazil.The were used in Bannana fields and must not have been to great because that were all that were sold.by the way my starting system is just a typical electric start.
