550 rear end fluid
sf
11-03-1998 04:31:25
shat type of rear end fluid is correct?
Kerry
11-04-1998 19:22:09
 Re: 550 rear end fluid in reply to sf, 11-03-1998 04:31:25
: shat type of rear end fluid is correct?
The Operator's Manual says "Use 102 082-A Transmission Oil Additive and premium quality SAE 10W-30 engine oil all year around except where temperatures are normally below zero degrees Fahrenheit, then use 102 082-A Transmission Oil Additive and SAE 5W-30 engine oil all year around. Mix the oil and additive in a ratio of
16 parts oil to one part additive or four gallons oil to one quart additive."
By the way the unit holds 5 gallons of oil and 2.5 pints of additive.
Kerry
11-05-1998 06:07:21
 Re: Re: 550 rear end fluid in reply to Kerry, 11-04-1998 19:22:09
: : shat type of rear end fluid is correct?
: The Operator's Manual says "Use 102 082-A Transmission Oil Additive and premium quality SAE 10W-30 engine oil : all year around except where temperatures are normally below zero degrees Fahrenheit, then use 102 082-A : Transmission Oil Additive and SAE 5W-30 engine oil all year around. Mix the oil and additive in a ratio of
: 16 parts oil to one part additive or four gallons oil to one quart additive."
: By the way the unit holds 5 gallons of oil and 2.5 pints of additive.
There was an error by me in the lighter weight oil to use. The book says 5W-20 instead of 5W-30.
Shade tree
11-03-1998 10:25:59
80-90 Wt gear lube.
