Super 55 Front Axle Bushing Question
Steve LeBard
03-14-2000 17:38:28
While working on my Super 55 Diesel, with Power Steering, I found that the front axle center pivot pin hole was elongated and the pin was worn. I posted a message and was told that the newer tractors came with a bushing and that I could bush this axle. I took it down to my local machine shop and had the work done to the tune of $190.00. When I went to put it back together it does not fit and now I think that the bore on the axle is not straight in and that they come bored at so many degrees of an angle. Am I on the right track and what should my next move be?
Thanks
Steve
Chris Losey
03-14-2000 19:26:22
 Re: Super 55 Front Axle Bushing Question in reply to Steve LeBard, 03-14-2000 17:38:28
You're right. We did the same thing and had to have it redone the right way. There is a 5 degree angle to the hole that bring the top of the axle a little closer to the front of the engine and the stabilizer bars down to their mounts.
D13
03-16-2000 16:36:35
 Re: Re: Super 55 Front Axle Bushing Question in reply to Chris Losey, 03-14-2000 19:26:22
So before I do mine, how did you fix it? re-bore the hole at the correct angle and rebush it? Ream/hone the bushing to get the angle?
Chris Losey
03-16-2000 19:49:21
 Re: Re: Re: Super 55 Front Axle Bushing Question in reply to D13, 03-16-2000 16:36:35
The machine shop we took it to drilled the hole out at the 5 degrees. He then made a steel sleeve insert and welded that in the hole. The inside diameter of the steel insert was the original size for the bushing. That way if the bushing gets worn, you can replace it with a stock one instead of having one custom made. (As long as you catch it in time.)
We had him drill it straight the first time and the axle braces were sticking above the floor boards.
Steve LeBard
03-15-2000 11:08:07
Thanks for the info, wish I had asked first but who would have thought. Hope this post helps someone else down the road.
Steve
Paul Stanley
03-16-2000 16:57:15
 Re: Re: Re: Super 55 Front Axle Bushing Question in reply to Steve LeBard, 03-15-2000 11:08:07
Yeah, my manual said to ream it out and leave .001" to .002" clearance for the pin, but it didn't mention anything about being bored out at 5 degrees.
