Steve T
03-14-2000 20:21:03
Re: Re: Re: Re: 88 standard UPDATE in reply to Dick L, 03-14-2000 06:25:09
I know exactly what you are saying. I was pretty excited when I first looked at the tractor, and didnt have much time to really get a good look at it the first time out. I was able to go back that saturday and spend about 2 hours playing with it (in the light of day). I found a lot more things wrong with it at that time,then when I first looked at it. I was almost ready to make a deal on it till the oil presure took a nose dive. It had 50lbs presure at speed with the engine still a little cold, and 25 lbs at idle. Well it lost almost all presure hot at idle, and only 25 lbs at speed. Still sounds like crank bearings to me. I still believe that they looked at the crank (with out a mic.) and probably thought it looked good enough for a set of new bearings, and left it at that. I am curently rebuilding a C-113 engine for my IHC model "A" tractor, and thought the same thing. A trip to the machine shop told a different story tho. It wound up needing to be turned .010 to clean it up. The machiniest said that it was slightly out of round, so I was WAY money ahead to have it turned instead of trying to "Get by" ,like what I think they did with the "88". I was told the guy spent $1400.00 in rebuilding the engine, and a quick look at rebuild kits told me he spent around $1200.00 dollors for the basic kit. I have almost $1500.00 dollors into the engine for my "A" and am still a little bit shy of enough cash to put the engine together, all that I have left is haveing the rods rebuilt. Its amazing how fast this little engine sucked up all my cash, but it is getting everything that I felt it needed, including timing gears,governor gear (a little over $200.00 for all three) lifters, hardened seats in the head, etc: and I know if he had REALLY went through the engine on the "88", he would have spent a LOT more then what I spent on my "A". I offered him $1800.00 and havent got a response back from him yet, so Ill wait and see. thanks for your insite. Steve T
