RC 88 Distributer
James Autry
10-27-1998 09:17:40
How do I get into the distributer to change the points? It appears to be sealed from the top below the rotor.
Von W.C. Ohio
10-27-1998 17:15:08
 Re: RC 88 Distributer in reply to James Autry, 10-27-1998 09:17:40
: How do I get into the distributer to change the points? It appears to be sealed from the top below the rotor.
On my 1955 Super 77's distributor you remove the cap and the rotor button and then there is a plastic cover that is indexed to keep the cap in the correct position . This covers the points and condensors and should lift off easily. It may be stuck if it has been painted over. This may or may not be how yours is set up but I would think it should be similar. By the way my distributor is a Delco what is yours ?
I hope this helps !
Von W.C. Ohio
Jim Autry
10-28-1998 10:46:15
 Re: Re: RC 88 Distributer in reply to Von W.C. Ohio , 10-27-1998 17:15:08
: : : How do I get into the distributer to change the points? It appears to be sealed from the top below the rotor.
: On my 1955 Super 77's distributor you remove the cap and the rotor button and then there is a plastic cover that is indexed to keep the cap in the correct position . This covers the points and condensors and should lift off easily. It may be stuck if it has been painted over. This may or may not be how yours is set up but I would think it should be similar. By the way my distributor is a Delco what is yours ?
: I hope this helps !
: Von W.C. Ohio
It is a Delco and it was painted over. I got it loose and am in the process of changing the points. Thanks
