I've never seen a 1650 without power steering - with a loader on a tractor this size power steering is an absolute necessity. 1650 brakes are excellent - work as nice as on a 4020, and cost a lot less to repair. Will lock the wheels on a hard road with moderate pedal pressure. Brake discs seem to last a long time, and are simple to replace when they do wear out. The 3-point is solid and has plenty of power. One minor complaint: The rockshaft and remote hydraulics are inactive at low idle. The motor's gotta be turning about 800 RPM or so before the hydraulics "wake up". (The power steering however works fine even at 450 RPM - probably result a priority valve doing it's job...) One other comment: I'd judge the standard ag wide front axle a bit light for loader work. The industrial wide front (solid plate beam axle with 900x20 tires) is a better choice for loader duty. So if the 1650 you're looking at has an ag axle, I'd look it over carefully for cracked welds, etc. Prices? That's a hard one to answer. Around here (upstate NY) I'd guess $4,500 - $5,500 with the loader depending on general condition, tires, etc.
