Oliver 77 just bought
Josh Barrowclif
03-06-2000 19:59:17
I need to know if there are any special tricks to remove the engine to install a new rear engine seal, also any help on clutch parts and brake parts would be appreciated. I am from Ames, Iowa.
Josh Barrowcliff
Mongo
03-06-2000 21:25:47
 Re: Oliver 77 just bought in reply to Josh Barrowcliff, 03-06-2000 19:59:17
The only thing different to it is pulling the PTO shaft before trying to remove the engine. Remove the PTO bonnet (two bolts under the bonnet) in the rear of the tractor and remove the 3 bolts that locate the PTO shaft and pull it out a few inches to get the spline out of the end of the crankshaft. The "shaft" you can see coming out of the bell housing is actually a hollow tube. You will see a fastener bolt on the tranny or belt end, remove it and the tube can then slide back toward the transmission. The bell housing can then be removed. The rest is pretty straight forward. Hope this helps.
Josh Barrowcliff
03-09-2000 19:19:23
 Re: Re: Oliver 77 just bought in reply to Mongo, 03-06-2000 21:25:47
Thank you for much needed info. That sounds pretty easy compared to what my friends were saying. "Split the tractor is the easiest way" they said. I am not looking for the hardest way, just the easiest. Thanks again!!
Josh
