Power Down 3pt on 1650
Skinner
02-26-2000 05:30:15
Is there an easy way to convert my 3pt to power down? I thought of adding a 2x8 DA cylinder on each side on my lift arms and tying them to the Aux hyd section. It would cost a couple of hundred bucks. Would this work? Any problems?
I really don't care to add weight to each one of my implements. (we share implements out here).
Mert
02-28-2000 15:37:00
 Re: Power Down 3pt on 1650 in reply to Skinner, 02-26-2000 05:30:15
What is current market value on a 1650 Oliver in good running condition?
Where can i find out what year it is if all I have is the Mof #265-12085 and Serial Number 176616-452.
Thanks.
Skinner
02-29-2000 03:29:53
 Re: Re: Power Down 3pt on 1650 in reply to Mert, 02-28-2000 15:37:00
I bought my 65 model 1650 for $2500 in running condition. Tires are 50% and very minor rust on the edges of the hood. The rest of the tractor is solid and I use it almost everyday. Its nearing 8800 hours.
Most of them around here go for 4500 to 7200 in the paper. They are proud of them.
Chris Losey
02-28-2000 21:21:42
Looks like it is a 1966, with narrow front and a diesel engine. Around my area it would go for $4,000 - $4,500 in good shape.
Shadetree
02-26-2000 11:52:31
Skinner Oliver used to make some tractors with external hydraulic cylinders but the 1650 was not one of them. The 1650 uses a smaller rockshaft arm than the ones offered with the external cylinders. I would not recommend changing it but if you decide to try it make sure that you let the internal cylinder all of the way down and tie the lever in the down position to prevent damaging it or the valving inside. Good Luck Shadetree.
Skinner - Thanks for the advice.
02-27-2000 16:37:54
 Re: Re: Power Down 3pt on 1650 in reply to Shadetree, 02-26-2000 11:52:31
1
