Noise ???
Elmer
02-24-2000 19:56:38
Is the rear end of a Super 77 supposed to make a whining sound like a B Farmall rear end? It has enough transmission oil, but I didn't know if this is a charecteristic of this type of tractor because this is my first oliver to work on. Thanks for the help.
WFE
03-02-2000 10:10:06
 Re: noise ??? in reply to Elmer, 02-24-2000 19:56:38
Elmer,
The geartrain noise in your Super 77 is perfectly normal, and although it may be a bit more pronounced now in the machine's later years, they had the same noise the day they rolled off the assemlby line. Oliver tractors, with the exception of the Super 55/550 etc. used selective spur gear transmissions, which are inherently noisy because of the great clearance between the gear teeth. As the teeth mesh (at high speed), the teeth contact one another and act like tuning forks. Listen next time your in road gear of pulling a good load, they sound a lot like tuning fork. With the introduction of the 880, Oliver began using helical gear transmissions in this and most later models. This was a vast improvement because helical gears are much tighter meshing, not to mention stronger, than the old spur gears. But that old sliding spur gear transmission sure shifts on the go nice compared to the constant-mesh helical transmissions so the noise is offset a bit by this advantage. Eventually the noise probably will grow on you as one of those Oliver characteristicsl, almost as beautiful as that smooth 6 cylinder engine.
Scott Green
02-25-2000 04:24:31
Elmer , Aaron is right.It was an Oliver trait.From what I had read , Oliver knew of this noise.They had done a lot of reserch to quiet this noise.One of the experiments they tried was pre-wearing the gears.They also did a lot of reserch on the fan noise.I never minded the noise myself.Many times I would hear a tractor running off in the distance.It seams like all the tractors have there own sounds.The engine , transmission , and fan noise is kind of like the Oliver tractor saying "HEY , IT"S ME".
Aaron
02-24-2000 20:42:59
I think the straight cut gears were that way. Our S77 screamed, my friends 66 will be noisy once it runs, just the way they are built.
Aaron
