Will It Fit???
Bill {Antique A
02-20-2000 19:27:46
Will a grill off a 77 fit a 66? Thanks Bill {Antique Acres}
Mongo
02-21-2000 22:14:45
 Re: Will It Fit??? in reply to Bill {Antique Acres}, 02-20-2000 19:27:46
Bill, I know the 88 and the 77 are different sizes but I am not sure about the 66. I can take some measurements off my 77 for you. Let me know and I could pull off the grill and bring it over.
Dsl
02-22-2000 07:27:39
 Re: Re: Will It Fit??? in reply to Mongo, 02-21-2000 22:14:45
This is only an educated guess, but because the 66 engine is just 2 cylinders knocked off the 77 one, there should be no difference in height or width. Also, the 66 and 77 have the same number of bars in the grille, so they should interchange.
02-22-2000 14:45:23
 Re: Re: Re: Will It Fit??? in reply to Dsl, 02-22-2000 07:27:39
That was my thinking and I have been told that they probably are interchangeable. Thanks Bill {Antique Acres}
B A Star
02-23-2000 09:43:16
 Re: Re: Re: Re: Will It Fit??? in reply to Bill {Antique Acres}, 02-22-2000 14:45:23
The difference in the grill shells between the 66 and the 77 is that the hole for the crank is higher on the 77 as compared to the 66. The engines in the tractor were raised at the front to allow the pipe for the mounted equipment to pass under the pan of the engine. That design continued through the last tractors ( engine runs uphill). As the 77 had a longer (2 cylinders) the front of the engine was higher in the 77. If you don't care about the crank hole you can use either.
