Here are some Specs from Deere Literature 8/98, and White Literature 5/98. This is what White has for competition for Deere in this HP. range Don't Know how well this will turn out but here it is..... Model JD 7410 , White 6810 HP 105 , 110 Engine JD 6.8 L , Cummins 5.9 L # of Cyl. 6 , 6 Asperation turbo , turbo Inj. Pump Rotary , Inline Fuel Cap. 50 gal. , 59 gal. Trans. 20 speed , 32 speed 5x4 8x4 Pwr. Quad Quadshift Shuttle optional , standard Creeper optional , optional Brakes Hyd. , Hyd. Diff Lock Yes , Yes PTO 540/1000 , 540/1000 Economy PTO Not Aval. , Standard Hyd. Sys. Closed Center , Closed Center
Psi Max. 2900 , 2900 Gpm Max. at remotes 27 , 29 Remote valves 2 , 2 (Optional) (3 or 4) , (3) 3-Point Cat. II , Cat. II Lift Capacity 7400 lb. , 9000 lb. (8390 Ib Opt.) Approx Weight 12,343 lb. , 10,190 lb. Warranty Not Disclosed , 2 yr. 2000h. (Opt.) " " (3 yr. 3000h.) (4 yr. 4000h.) Price HIGH AS HELL , REASONABLE Loaders 740 & 840 , 688 & 688LL Make your decision on the specs they don't lie.
Other Oliver Trators to Consider: 1855, 1955 98 hp, 108 hp Other White tractors to consider: White 2-88, 2-105 2-110 100 White American 80 White Workhorse 125 E-mail me questions you might have. I've got literature on this stuff. 7000 series tractors do have some 3-pt problems, and some things are difficult to service.
