Super 77 hesitation problem
Bill
02-16-2000 06:25:18
Have a unique problem with my super 77. This summer, I put in a new clutch and cleaned out the sediment bowl whose connection to the gas tank was clogged with years of small pebbles and grit. All the pertinent electrical components are new-cap, rotor, coil, plugs, wires, wires to and from generator, etc., condensor and points. After the sediment bowl was cleaned out, I discovered the carb settings needed adjustment because they had been set to compensate for the plugging (unknown to the prior owners apparently.) The idle is now set fine and it runs well. The problem is when I let out the clutch and under load. If I let the clutch out slowly, everything is fine. If I let it out at what I would consider a normal speed, it bogs down and stalls if I don't push it back in. This also happens if I push or pull a heavy load. As I have a loader attached and use the tractor primarily in this capacity, I would like to cure the annoyance. I've played with the high load adjustment on the carb with a bit of success. Any ideas?
D13
02-17-2000 20:02:13
 Re: super 77 hesitation problem in reply to Bill, 02-16-2000 06:25:18
Having had exactly the same problem on my Allis, I agree that the carb is the most likely area. If you've never done a carb, this is a good one to work on. Some suggestions:
1) Gold Eagle (or others) sells a gallon can of liquid carb cleaner. Get it. I have used mine for 20+ carbs and it's still going strong. Basically, you need to take the carb completely apart and soak it to get all the crud off. 2) The gallon can usually has a dip bucket in it. If your carb is too big to fit (yous shouldn't be, but you can never tell), a disposable baking pan (the 9x9 works best) can be used. This also helps keep the big chunks out of the can.
3) Carb cleaners dissolve toothbrushes, but they work well enough to get the dirt off. A small stiff bristle paint brush works well in the corners.
4) When you take the carb apart shake the float to see if gas is seeping in (although unlikely if you have the leanout).
5) Do not soak any rubber parts such as needle valve seals - these will dissolve.
6) Be sure and check the contents of the kit - sometimes there are not replacements for all the seals. Some kits have new needle valves in them.
7) Make sure the kit gaskets mathc your carb (this can be a problem with "universal" kits).
8) After soaking the carb parts about half an hour, scrub them, then hose them off with spray carb cleaner. This can be used to blow out the passeges too. This removes the dip cleaner, plus any remaining slime. I find it takes 1-2 cans depending on how dirty the carb was.
9) Carb cleaner evaporates very quickly and will dry your skin (think high-flash lacquer thinner). Wear rubber gloves. I personally have a large wire-mesh sieve (I paid $3 for it at Lechter's) and put the parts in it for spraying. 10) As you take the carb apart, compare it with the kit's instructions. you should be able to identify the parts well enough to get it back together.
Be happy - myfirst carb job was a 4 barrell Quadrajet with electronic emission controls - it took me 6 hours. I did my Zenith in 1 hour the other morning - mostly soak and dry time. Good luck!
Bill
02-18-2000 06:19:46
 Re: Re: super 77 hesitation problem in reply to D13, 02-17-2000 20:02:13
Thanks guys. I found a rebuild kit yesterday (and carb dip cleaner) and will tackle the job this long weekend. Thank you for all your assistance. I'll let everyone know how it turns out.
Shadetree
02-17-2000 10:44:38
Bill normally when you purchase the kit the insturtions for rebuilding are included, they will explain what to set the float at and what the prelimenary adjustment for the idle jet and the main load jet should be to get it started. They usually go on to tell how to get the final settings for both jets. Good Luck. Shadetree
bastar
02-16-2000 20:33:28
The previous answers are all good ones. The engine is running so lean that when the throttle disc is opened for any reason, the mixture is so lean it dies. The carburator has an acceleration well around the main fuel nozzle, with some small holes from the well to the inside of the tube. When the throttle disc opens, it speed the air flow up at the end of the main nozzle creating a lower pressure area at the end of the tube causing the fuel to flow out of the well. In other words, make sure that you remove the main fuel tube (a brass tube in the center of the trought) and clean it.
Bill
02-17-2000 06:27:41
 Re: Re: super 77 hesitation problem in reply to bastar, 02-16-2000 20:33:28
Thank you to everyone for the tips. I will tear into the carb this weekend and see how dirty, worn things are in there. Then rebuild it if necessary. Where is a good place to go for steps in rebuilding the carb? Or is this info included with the rebuild kit? I've never had to rebuild one yet. I have the operator's manual and abridged shop manual, but they don't cover the carb and its repair at all.
Scott Green
02-16-2000 14:03:51
I've had the same problems in the past.It was in the carburator.Take it apart , clean it , blow it out with air , make sure the float is set OK , make sure the float is not filling up with gas.If you do buy a rebuild kit , buy a good one.Don't buy a Central Tractor kit.Central Tractors's needle and seats are junk.The gaskets are OK.Another sign of a dirty carburator is when you have to run the tractor with the choke out.Also , Central tractor's ignition parts are no good.Buy quality parts.In the past , every time I had let my guard down and bought Central Tractor parts because I was in a bind , I would have problems.I would have to go and buy good parts the next chance I had.
Bill
02-17-2000 06:31:39
 Re: Re: super 77 hesitation problem in reply to Scott Green, 02-16-2000 14:03:51
What is the float setting for the Schebler (sp?) carb on the super 77? (It isn't the Zenith carb.) My shop manual is abridged and doesn't offer the spec.
Scott Green
02-17-2000 16:16:28
 Re: Re: Re: super 77 hesitation problem in reply to Bill, 02-17-2000 06:31:39
I set all my floats on "Marvel Schebler" caburators at 1/4".Without looking in the book(which is out in the shop),I blieve some are either 3/16" , or 5/16".I would have to look.I have no problems setting mine at 1/4".
Shadetree
02-16-2000 07:47:03
Bill have you had the carberator rebuilt yet? You may have a problem with the float being set wrong, or sediment inside of the float bowl, or even a float that has a hole in it and has started filling with fuel. Also when you cleaned out the sediment bowl did you remove the sedement bowl base from the bottom of the fuel tank? Some times the entry port going into the base unit gets clogged up with small debris, this is a common thing to have happen. The way you can tell if you have good flow coming out of the sedement bowl base is to remove the glass bowl, then open the valve wide open and you should see two distinct streams of fuel coming out spraying to each side in almost pencil sized streams. If it appears to be one small stream then remove the base unit and cap the tank with a 3\8 pipe plug temperailly so that you can turn the base upside down and tap out what ever is inside. Reinstall the base and go again. I would try the sediment bowl base first, and then consider spending the money to rebuild the caberator. Good Luck Shadetree.
Bill
02-16-2000 11:11:38
 Re: Re: super 77 hesitation problem in reply to Shadetree, 02-16-2000 07:47:03
Thanks. I checked the sediment bowl base and there is good flow. Gas supply isn't the problem. No, I haven't taken the carb apart and checked it out. Will do that. Any good suppliers of rebuild kits you know of?
Shadetree
02-16-2000 23:05:22
 Re: Re: Re: super 77 hesitation problem in reply to Bill, 02-16-2000 11:11:38
Bill a lot of tractor dealers have some outside venders that they can purchase parts from for tractors that they don't normally sell. If you check with about any tractor dealer they can problably order you a complete carberator kit. I have had good luck with Tisco brand kits. Also don't order a float unless you get inside and find out that the float is filling with gas. The floats can be a little bit cashy to buy if you don't need one. Also any Agco dealer should be able to come up with a carb kit for you as well. Make sure you use regular carberator dip cleaner to clean out everything inside of the carberator or take it to somebody who has this kind of cleaner as well. Good Luck and I hope to hear how you are getting along. Shadetree.
Dick L
02-16-2000 07:40:29
What happens when you pull the gas lever down very quickly? If it starts to die when this happens it might be a air leak some where between the head and the carb. This is asumeing that the carb has no dirt floating around in front of a jet. I fought a problem like this in one of my 77's and it was the manifold gasket and the same with my 66 and the 66 had dirt in the carb that I had taken apart several times. Didn't get it to run correctly untill I actualy removed the jets. I never saw the dirt but after I put it back togather it ran ok.This may not be your problem but it's another place to look. good luck and have fun
