Oliver 1850 Flywheel ring gear
Os Blacker f
10-10-1998 18:32:04
I am having difficulty in obtaining a flywheel ring gear for an Oliver 1850 Diesel tractor.
I have tried Lind Implement but to no avail.
Can anyone suggest another source.
Thanks in anticipation Os Blacker.
mm
10-17-1998 14:33:29
 Re: Oliver 1850 Flywheel ring gear in reply to Os Blacker from Down under, 10-10-1998 18:32:04
: I am having difficulty in obtaining a flywheel ring gear for an Oliver 1850 Diesel tractor.
: I have tried Lind Implement but to no avail.
: Can anyone suggest another source.
: Thanks in anticipation Os Blacker.
Hi, Does your 1850 have a 354 Perkins in it. If it does you might want to consider going that route to find a ring gear. 354 Perkins were used in 750 Massey Combines. It would be worth seeing if that would be the same ring gear. Good luck.
Von W.C. Ohio
10-12-1998 18:56:18
You might also try Farmersville, Equipment Inc.
They list as having 200 Oliver Tractors dismantled for parts.
142 East Farmersville Road
P.O. Box 638
Ephrata, Pennsylvania U.S.A. 17522-0638
Phone 1-(717)-354-2150
Fax 1-(717)-355-9909
Von W.C. Ohio
10-11-1998 17:41:06
Give Maibach Tractor a call at Creston, Ohio.
They have a large selection of used Oliver parts and have many salvage tractors dismantled for parts and ship parts all over the world. Contact them at the following:
Maibach Tractor
phone# 1-(330)-939-4192
or 1-(800)-808-9934
fax 1-(330)-939-4483
Hope this helps you out !
Von W.C. Ohio
