Cletrac Model EN
Roland Goudreau
10-09-1998 19:40:00
Would Like Any Information On This Model : Age, Use ,PartsAvailability.Hercules OOC Eng.
richard
10-16-1998 06:46:26
 Re: Cletrac Model EN in reply to Roland Goudreault, 10-09-1998 19:40:00
: Would Like Any Information On This Model : Age, Use ,PartsAvailability.Hercules OOC Eng.
I will try to help. I believe that you have a cletrac E narrow. this tractor was made in 1934 till 1941. If you have the serial no.
I could give you the year. It had a Hercules L-head, 1300 RPM, 4X4 1/2 inch bore and stroke.
Weight was 6100 LB. 19 drawbar HP. Richard
Roland
10-27-1998 19:22:25
 Re: Re: Cletrac Model EN in reply to richard, 10-16-1998 06:46:26
: : Would Like Any Information On This Model : Age, Use ,PartsAvailability.Hercules OOC Eng.
: I will try to help. I believe that you have a cletrac E narrow. : this tractor was made in 1934 till 1941. If you have the serial no.
: I could give you the year. It had a Hercules L-head, 1300 RPM, 4X4 1/2 inch bore and stroke.
: Weight was 6100 LB. 19 drawbar HP.
: : Richard I Have Found This To Be A 1935 Serial# 6B26 and a weight of4900lbs from the original oprators Manual Thanks For Any help
