RC-88 PTO Problems
James Autry
10-07-1998 09:23:17
I have to force the PTO engage lever all the way to the end of its travel in order to operate the PTO. Has anyone seen this problem? Has some gear slipped position?
Thanks
Jim
BOB F
10-12-1998 15:18:42
 Re: RC-88 PTO Problems in reply to James Autry, 10-07-1998 09:23:17
: I have to force the PTO engage lever all the way to the end of its travel in order to operate the PTO. Has anyone seen this problem? Has some gear slipped position?
: Thanks
: Jim
I know what your problem is. Bob at [email protected] Waiting for a response.
BOB F
10-12-1998 15:17:00
: Thanks
: Jim
BOB F
10-12-1998 15:15:21
: Thanks
: Jim
Shadetree
10-07-1998 09:57:08
: Thanks
: Jim
Jim it sounds as though your clutchs may be slipping. You may need to take the pto cover off of the back and very carefully remove some shims from between the clutch housings, only to remove the exact same thickness of shims from each of the three shim packs. You can use a micrometer to mesure each shim but they should all be the same. These shims are usually stuck together and have to be sort of peeled apart. I would recommend removing 3 shims from each pack at first and then maybe 1 or 2 after that. Good Luck and if you have any more questions ask.
