Super77?
Jim Dixon
10-04-1998 08:40:39
We have an odd ball tractor on our small farm. According
to some folks who have called us when we had the thing listed
for sale, it would be a Super 77. One caller told
me to check under the distributor to see if there was
a removable plate w/4screws. He said this is where an
optional tachometer is attached. Our tractor has this plate.
Another caller advised me to check the front end castings. He
advised that the Super 77 used a "sort of squared off look" versus
the "rounded look" of a Row Crop 77. Our tractor has the
rounded look. However, our tractor has side sheet metal
with the decals for a Super 77. On the tractor's ID plate
it clearly states Row Crop 77. It appears that the tractor
was either a mix-matched thing from original production, or,
someone changed engines and sheet metal. Any suggestions? Thanks, Jim Dixon 717-469-1519.
Von W.C. Ohio
10-04-1998 11:00:53
 Re: Super77? in reply to Jim Dixon, 10-04-1998 08:40:39
: We have an odd ball tractor on our small farm. According
: to some folks who have called us when we had the thing listed
: for sale, it would be a Super 77. One caller told
: me to check under the distributor to see if there was
: a removable plate w/4screws. He said this is where an
: optional tachometer is attached. Our tractor has this plate.
: Another caller advised me to check the front end castings. He
: advised that the Super 77 used a "sort of squared off look" versus
: the "rounded look" of a Row Crop 77. Our tractor has the
: rounded look. However, our tractor has side sheet metal
: with the decals for a Super 77. On the tractor's ID plate
: it clearly states Row Crop 77. It appears that the tractor
: was either a mix-matched thing from original production, or,
: someone changed engines and sheet metal. Any suggestions? : Thanks, Jim Dixon 717-469-1519.
The plate with 4 screws is also where a gear driven hour meter can be installed. I have one on mine and it is a 1955 model Super 77 but I have also seen a couple with a tachometer (like from a 770 attached). What serial number is on your tractor ? I have linked the serial number reference page below hopefully it will work.
Von W.C. Ohio
Von W.C. Ohio
10-04-1998 11:02:54
 Re: Re: Super77? in reply to Von W.C. Ohio, 10-04-1998 11:00:53
: : : We have an odd ball tractor on our small farm. According
: : to some folks who have called us when we had the thing listed
: : for sale, it would be a Super 77. One caller told
: : me to check under the distributor to see if there was
: : a removable plate w/4screws. He said this is where an
: : optional tachometer is attached. Our tractor has this plate.
: : Another caller advised me to check the front end castings. He
: : advised that the Super 77 used a "sort of squared off look" versus
: : the "rounded look" of a Row Crop 77. Our tractor has the
: : rounded look. However, our tractor has side sheet metal
: : with the decals for a Super 77. On the tractor's ID plate
: : it clearly states Row Crop 77. It appears that the tractor
: : was either a mix-matched thing from original production, or,
: : someone changed engines and sheet metal. Any suggestions? : : Thanks, Jim Dixon 717-469-1519.
: The plate with 4 screws is also where a gear driven hour meter can be installed. I have one on mine and it is a 1955 model Super 77 but I have also seen a couple with a tachometer (like from a 770 attached). What serial number is on your tractor ? I have linked the serial number reference page below hopefully it will work.
: Von W.C. Ohio
Trying to link again !
Here is the address if this does not work
Link
Von W.C. Ohio
